I posted previously asking about the feasibility of moving some radiator piping that runs along the ceiling in my basement. I finally had a contractor come out and take a look, and what he was suggesting was replacing the existing cast iron with copper at a reduced diameter.
I believe the primary supply / return lines now are about 3" cast iron and maybe 1.5" or so for the branch supply and return lines. What he wanted to replace this with was 11/4" copper for the primary supply and return and 3/4" for the branch lines. His rationale for the reduced diameter was that when the system was installed originally (the house is from 1925), the system would have been gravity based and that required a larger diameter pipe. Now that the system mechanically circulates the hot water, smaller diameter copper would be OK.
Is this legitimate? I want to make sure I'm not crippling the heating in the front half of my house by making these changes. To lend credence to his explanation, I do see that when the boiler was replaced the primary supply and return cast iron pipes that service it feed into narrower (probably 11/4) copper to actually enter and exit the boiler.
