JoeBean
Hi all,
We just bought a house with a for-all-intents-and-purposes unfinished basement that we're putting an apartment in for my mother-in-law. The house is about 20 years old and well built for the most part, but the homeowner plumbed it himself and it's a godawful mess. So I'm planning on tearing most everything out and replacing. With that in mind I have a few questions:
1. The supply line is 1/2" copper. I'm worried it'll be too small to keep up so I intend to upgrade it. So with regard to this:
Would you suggest 3/4", 1", or larger?
And would you recommend PEX or soft copper? There's already a separate grounding electrode for the electrical system.
2. I'd prefer to run PEX for ease of installation. Which system would you recommend? I'm inclined to go with Wirsbo due to it's reputation, but it's not used much (and so few components are stocked at the local plumbing supply stores) around here so everything will have to be ordered in, and my wife is worried that we might have a failure at some point and then be stuck waiting for parts. Crimp systems are the most common around here. How do they stack up? Are there differences between brands? And what about clamp systems?
3. Venting is the biggest problem. Currently all drains are coming off of 2 stacks at one end of the house, approximately 12' apart. Neither stack is vented directly. One stack, which currently services the kitchen sink, dishwasher, and the laundry room has an AAV installed on it. The kitchen sink also has an AAV, and there's another one (!) on the run to the washer. All of the fixtures are with 5' of the stack. The 2nd stack just services the washroom. One line runs from the vanity to the stack, about 2' total, with an AAV at the vanity. The second line starts at the only actual vent pipe in the house and goes about 2' uphill to the tub drain, then another 10' to the toilet drain, then 3' to the stack.
Venting has me the most confounded as I've never been able to find anything stating clearly the proper way to do it, and much of the info I have found is contradictory. So my 2 questions for this are:
Would it be sufficient to vent the top of both stacks in addition to a properly ran vent where the existing vent is situated? This, of course, isn't taking into account the extra fixtures to be added in the apartment - I just want to know if I'm understanding what should have been done.
What resources (online or books) would you recommend reading to cover plumbing code requirements for Canada?
Thanks a lot for any help you can give. I very much appreciate it!
