We get about 12-15 yrs out of them around my service area. That’s if it’s sized properly.How long are water heaters usually good for? I may need to replace mine. I think we got it replaced when Dad was still alive (so before 2009). I think mine is a whirlpool.
Someone told me about a problem with many Rheem water heaters where the pilot light won't stay lit. Rheem had a supply chain issue due to Covid and switched control valve manufacturers for a year. A large percentage of those valves went bad, and Rheem has been horrible about covering it. The control valves that are bad are gray. I happened to buy mine from Home Depot early in the pandemic and it's a Rheem so I went to check the color. Mine is white (Honeywell), whew...
What's the best brand in your area for gas water heaters, in terms of service calls? I've had AO Smith (already there when I moved in, not impressed), then Bradford White (lasted 9.5 yrs, opted to replace since our HOA mandates 10 yr replacement anyway), and now Rheem (so far so good). Thanks.Those go bad too, a lot of them. I’ve changed 10-15 of them in the past few years alone.
Electric water heaters have the cheapest parts. Easy to get and work pretty good.
They all have problemsWhat's the best brand in your area for gas water heaters, in terms of service calls? I've had AO Smith (already there when I moved in, not impressed), then Bradford White (lasted 9.5 yrs, opted to replace since our HOA mandates 10 yr replacement anyway), and now Rheem (so far so good). Thanks.
Good to know, I usually just buy the cheapest one. Esp since our HOA mandates we replace them every 10 yrs so seems like brand (and maybe even maintenance) doesn't really matter at that point.They all have problems
