PerplexedPlumber
Common problem with that system.
With less experience than either of you, and DIY, the only leak I had was chronic from the beginning. When the cuts are made correctly and the tool is not damaged and is used correctly, I have not had problems. The one leak was when I used a cut that was slightly off the 90 degree angle.
When you find problems, have those been poorly connected, or do you find problems when the cuts and crimping look good?
