Hangernail
I recently built a new shop with in slab radiant heat. The heat source is an outdoor wood boiler that circulates water through a heat exchanger. The radiant system is a closed loop system with glycol/water mixture. It's been running for about a week and it just doesn't seem to be getting warmer than 10 degrees. The boiler pipes are circulating fine at roughly 180 degrees and the glycol in the closed loop seems to be getting heat from the exchanger (180 degrees at heat exchanger and 100 at supply manifold after mixing valve). The returns have never got any warmer than about 65 and the temperature in the shop has never gotten above 10 degrees Celsius. I have tried a few times to purge more air out of the closed loop and am not having any success. Any ideas or suggestions would be much appreciated.
