thechaosboi96
So in my apartment 1 story, there's a master bedroom and a master bathroom, right next to each other. The room's bedroom's floor by the wall right next to the bathroom started to get wet and soaking up the carpet. the wet area is side by side to where the tub is located from the other side, not the toliet is. So they though toilet had a leakage which causing water leakage to leak over to the bathroom but that wasn't the case. So the floor got wet again in the room. Now they've located that underneath the tub inside is crack causing water to run into the bedroom, but we haven't used that tub since then. But the floor is still getting extra wet. Any reasons to what the problem can be? Thank you.
