Centrifugal pumps work on Total Dynamic Head (TDH). So roughly they add if you select the correct pumps.. Think of deep well, multistage submersibles. They will frequently have 13-stages, or stacked pumps to generate the head needed to push water up several hundred feet, and generate 60-psi at the surface.
We used to build large reservoirs of 20 to 100 million gallon, with adjacent pump stations constructed with the pumps approximately twenty feet below the bottom of the resrvoir to help prevent cavitation..
We had to account for that positive suction head, as opposed to the normal negative head seen in small systems, in the selection of the pump to optimize the wire to water efficiency.
TDH=( Net Positive Suction head + discharge head + friction Head).
It takes a bit of physics, to start to really understand it, but you can get a functional understanding with just algebra and a good book.
