Hello All,
Looking for some opinions on the best pump/pressure tank set up for my folks new house.
Specs: House 350' from well, 80' deep rock well with 2" casing. Static water level 5' below top of well. Haven't pulled the drop pipe yet, but generally they are 20-30' with a foot valve around here.
I tested with a 1 horse utility pump and got a consistent 12 gpm. (Pump is rated for up to 24 gpm but it is old and wore out.)
Want to have good flow and pressure at house. Option A Pressure tank $ switch beside pump. Option B Pressure tank & switch close to house, Option C Small pressure tank attached to pump, main pressure tank close to house.
Any input will be appreciated
