dsthomas23
- Joined
- Oct 14, 2022
- Messages
- 1
- Reaction score
- 0
We live a in small town and have a 6500 square foot home. We have been told we needed a new pressure tank, a new pump, different routing of plumbing, etc. by a number of local plumbers...but it never seems to be correct. We have a new pump that was installed and I just do not think it was installed correctly. It is not bolted to the ground for one, it shutters if it starts, and also is throwing an error code after a short time. It is a new Scala2 pump and error code #3 is showing which appears to have the non return valve blocked or defective. It just started showing this code after a valve was closed (as seen in picture at top near ceiling where old yellow pipe meets new white pipe) that was done to prevent water pressure from dropping after 15 seconds on our sprinkler system. It basically has not been working properly all summer, but did not know that since it goes off at 4am. We have a sprinkler system, inline water heater, pressure tank, water softener and plumbing pipes that have been changed around by every plumber that touches them. Any help with a layout or different idea of a schematic would be greatly appreciated. Going to call plumbers again to check on error code in the interim. FYI....City pressure comes in at about 60. WE also get pipe shutter when the sprinklers come on. Thank you for any thoughts.
