Hi,
I'm planning a solar-powered irrigation system that needs to pump about 20-25m³ per day.
My water source is either a creek (max 8m difference between source and destination) or a well (max 11m).
I am not a plumber, so I don't know what type of pump to use, pressures, pipes etc...
The system doesn't contain any sprinklers but flows out the end of a pipe, so there is no need for significant pressure at the end.
What other factors do I have to consider? Is there a controller I can use to supplement the solar system with mains power in case of a cloudy day or higher demand?
Thanks
Thanks
