I can tell you that you could fry the circuit board if you try to run less than needed gas on a Navian TWH.
You will not get any viable advise for gas on this forum. Some things need to be left to professionals. Would you ask your doctor advise on performing your own open heart surgery?absolutely no offense, but will not consider hiring a plumber for this job.
Like changing winter tires on a car could be very dangerous if not done by an official car dealer.
As I said, I would like to do it safely and hope to get advice on the proper way to do it.
Common sense I will be the only one taking full responsible
ok thanks I will make sure I have enough gas supply firstI can tell you that you could fry the circuit board if you try to run less than needed gas on a Navian TWH.
The project you are planning is nothing like just changing your car tires.
I feel sorry for your neighbors if your house explodes or burns, taking their houses with it.
Do you know if you even have enough gas pressure coming from the meter?
I came here to look for help. I did listen and trying to learn from you nice guys here.Why should we continue to try and offer advice when you do not listen and refuse to heed warnings. You are in over your head and obviously cannot figure it out yourself. A dangerous combination when a mistake could have devastating consequences. Have fun “changing your tires”, but get your advice elsewhere im done trying to help.
Having 5 psi doesn't say anything. You need a manometer test to verify sufficient volume for the TWH.
Trying to simplify what is going on, my Cadillac has a speedo that goes to 160 mph. Will it hit 160 mph? Hell no. Your meter says it's capable of pushing 250CFM's. Will it? One 90• elbow will reduce it drastically. One 1/2" pipe will also reduce your flow drastically.
A manometer you can consider as similar as putting your car on a dyno. It will confirm whether you have the power necessary to drive 160 mph. Does this make sense to you?
This poster is either a troll just pulling our legs, or someone dead set on blowing up their house by not hiring a pro as they should.
IMHO.
