3000 sq ft home, 2 and 1/2 baths, single story, concrete slab. The two full baths are on the other side of the house as the water heater. Installed the pump and a sensor valve in each of the full baths. No change in time to get hot water, still takes over 2 minutes. Have confirmed installation is correct. I don't know if I should put more money into adding valves or return the pump and cut my losses. Any ideas?
