Amtrolman59
I installed a new Amtrol well-x-trol WX-202 pressure tank (20 gallon), Square D Pressure Switch 9013(30-50) and a new pressure gauge, The tank pumps up to 50psi and drops to 30psi when running a faucet but when taking a shower the water drops fast below 10psi to zero and I run out of water, If you turn the shower off and wait about a minute or two then you have water again, Seems like the pump is kicking on at the 30psi cut-in.
