Maybe you guys can help me because PF sure cannot. What they told me just doesn't make any sense to me. So I have a weird application - a very large RV with a residential corner shower. The shower trim looks really bad so I purchased a new trim kit from PF. The shower valve is ~18 years old, but I was able to get a new cartridge (9740420) and a new trim kit (PF Weller Trim Kit). The shower valve is held to the fiberglass shower with a custom bracket. So it all went together with no issues, but here is a strange problem. Even though the cartridge and faceplate are very rigid, when I install the handle on the plastic stem on the cartridge - the handle is anything but "rigid". It moves around some when turned and that bothers me. The guy at PF said "yea, that can happen with older shower valves", but I don't really see how that plays into it. It seems like it's either the keyed fit to the handle or the stem of the cartridge itself has movement. I could shim the valve body back into the wall more, but I don't see what that would help. Just as an aside, there is re ally no good way to change the valve without tearing out wallboard that is not available anymore.
Any fixes I can try from you experienced fellas?
