jwwing
My house was built in 2005 and we moved in April 2006. The water pressure outside was about 100 psi which was too high for the hoses so I asked to have it reduced. They installed a regulator and adjusted it to 75 psi (minimum it will do). I checked the pressure but it was too low and inside the house would hardly run. So I went to the regulator and ended up adjusting it to the max to get things ot even work. At least the outside was ok at the new pressure (the max setting is 100 psi, but it is nowhere near that).
Now the pressure and volume at the outside bibs is ok, but inside it is not.
We have a big separate tub with circulation pump that fills fine. It acts like it has a 1" pipe on both hot and cold, but at the opposite end of it is a shower with such an anemic flow that it won't operate a pulsing shower head. I can live with that, but it is sad. There must be a restriction device on there - where do I look and what am I looking for? I can't find it.
But the main problem is the kitchen sink. Before they reduced the pressure, we had reasonable pressure at the sink faucet and decent flow rate, but now it is too low. I have searched and cannot find any restrictions (eg, washers with 1/8" hole).
Please tell me what should I look for and where will it be located?
Thanks!
Thanks!
