Hi,
We are in contract to purchase a forclosure. The water was turned off, winterized and the water company removed the meter (which is needed to turn on the water). They also cut a main pipe into the house to drain it. (We don't know why they did it this way and doesnt make sense to us either). We had a plumber do a pressure test today since there was no water and he advised there was an immediate drop 30 lbs of pressure.
From what we have been told by the water company- water was turned off in 2010 and water drained/pipe cut/meter removed in 2013.
There are no visable signs of any water leaks or mold or mildrew (execept the basement which is minimal mildew due to outside water seeping in when it rains- recommendation is humidifer)
We also know the water heater is 19 years old and should be replaced soon but not immediate
Right now we are waiting for Fannie Mae (who owns the house) to have the water turned back on before we either back out or get an estimate on whatever the next steps are.
Here are our questions.
- is it possible the plumber missed turning off a valve to get such a large and quick drop in pressure?
- if a pipe had broken, wouldnt we be able to see some sign of damage due to the break by now?
-if multiply small cracks/slow leak cause a drop in pressure that great?
- how difficult /costly is it to have a plumber come and find/fix leaks (we are trying to figure out worst case scenario) ?
Any help or advice is greatly appreciated.
Thanks!
Thanks!
