Leo 'Gus' Gustafsson
Active Member
Hi gang,
When we first moved into this home 7 years ago our kitchen faucet was flowing fine, but after a couple of years and after replacing the water heater, the hot water flow diminished. Fearing the worst, after shutting off the water,I removed the Supply Line an turned the valve back on to check if the impediment was in the main line. It made a mess, but the problem seemed to be down line. The Supply Hoses checked out fine, no kinks or blockages. I replaced the faucet (quite a sticker shock) and it turned out the stoppage was in the faucet itself. We were happy.
Now it's happening again, and replaced with another budget faucet ($90) I'm a rank novice when it comes to plumbing, but I can say that the pipes in this 1968 house are galvanized. we did have flow problems in the bathroom as well but replacing the fixtures seemed to clear that up as well. A 5 year life span seems way to short for such elemental plumbing, am I missing something here?
Thanks and a lift of the lynch lid for your responses.
Gus
Gus
