Studhauler
Active Member
I would like to use a water cistern for my potable water supply, during periods of extended electrical outages. The info I could find about doing this, says to start with municipality treated water. I will be using water from a private well (raw water). That source says treated water is only good for two days in a cistern, unless one watches the chlorine level.
I am sure there are people out there that use raw water in their cistern. What are you doing?
Thanks for your help.
