Please help! I am in quite the conundrum. I was supposed to get a new gas tankless water heater installed today. The plumber came today and after removing my old tankless heater realized that the previous owners were venting heater and furnace through the same pipe, through the roof, like a “y”. I see online that this is not uncommon, but the plumber says that my issue is that the current setup is with a category 1 vent pipe, while the new heater requires a category 3 a d said it shouldn’t be vented with other appliances. He can’t vent it somewhere else because it’s in the crawl space and the only options would end up being near a door or window. So, I’m stuck trying to find a solution, while also now being without hot water because he couldn’t reinstall the old heater after breaking it apart to uninstall. He said this was due to difficulty removing it because of age. Now he says my options are getting an electric tankless heater, but that requires hiring an electrician to run conduit, etc., which also isn’t easy because of the way the crawl space is designed and will be costly. Especially with it being the weekend. As a last resort, I even looked around for a regular water heater, but there are none available locally to fit the crawl space and absolutely no where outside of the crawl space to put it. He also mentioned having the HVAC venting system restructured, which requires tearing down a wall, etc., and even more money. I want to believe that there has to be a way to install this thing with the current venting setup. Any suggestions or advice will be greatly appreciated. Thanks, Maria
