syq4ever
I have an inspector coming later to check on the electrical panel that I am currently upgrading and part of the job is to ground/bound the water heater (according to the electrician). As the electrician was bounding some wire on my water heater, he noticed that the previous owner did not have the discharge pipe that is near the wall and run outside to the house connected to the TPR valve. So he said that I must have it connected as it is required and the inspector will look at it. So my question is, can I use this product from Home Depot to make the connection from the water heater release valve to the discharge pipe: Home Depot - 3/4 in. x 18 in. Lead Flexible Water Heater Connector 3/4 in. with Ball Valve customer reviews - product reviews - read top consumer ratings
Thank you so much for your help!
