psklein578
Active Member
I will try to make this short. I have a well with a pitiless adapter. The pipe on the discharge side has developed a leak (again). I did the necessary work to find the place where it is probably leaking. The original leak was a bad pvc joint that was not fully joined. The pipe to the house lines up offset to the side and below the adapter outlet. I repaired the original leak two years ago. The ground has settled in that area. Unfortunately it’s under a sidewalk.
How can I stabilize the pipe so that doesn’t happen again? I tried filling around it with p gravel. Maybe concrete would be better?
Pictures show the before and after repair two years ago.
