jebber45
Hello Everyone,
I have an issue that has been very difficult to diagnose. We moved into our home in September, and have had heard on several occasions a loud humming/buzzing/vibration noise coming from in the wall between our master bedroom and master bathroom. In the past, we would hear it for about 30 seconds, and it would stop. I never thought too much of it. The timing of the sound was pretty random- we would hear it maybe once or twice in a week, and then not again for 3 weeks. The sound would go on after using the shower ususally, after the shower was turned off .. and last for about 30 seconds.
Recently, we have been hearing it more often. We have also been hearing it in another spot of the house - underneath the kitchen floor near the powder room. This spot begin buzzing this week and lasted over 30 minutes.
Turning on a faucet would muffle the sound a bit, but once you turned it off, it would come back on.
I went to the basement and was able to get the noise to stop when I closed the cold water valve that was supplying the kitchen & powder room. When I would open up the valve, it would start again. Interestingly, closing the entire house main did not stop the noise.
We have had a plumber out, but unfortunately did not get anywhere - because we are not able to replicate the noise. Some days I'll get out of the shower and it will start buzzing .. most days though, it won't. The only thing I notice is that when it does start humming, is usually at a time where I just stopped using water in that area.
It does not sound like typical pipe banging from unsecured pipes. And there have been stretches where the sound has lasted 30 minutes.
At this point it is a nuisance, but I'm concerned a bigger problem could be around the corner.
Thank you so much for any help you can give me. We don't have the money to have someone cracking open walls to "fix" things we aren't sure are the problem.
James
James
