hdtvkeith
About to re-pipe my home. half the pipe is in the basement ceiling with the copper hung form the ceiling joints with wire hangers holding it tight to the joists. I will be using Pex and I see Pex needs to be held every 36 inches and needs to be slack for expansion/contraction. Over the years with all the power and Cat 5 cables added the basement ceiling is a mess to run pipe the same way. If I build a sort of trough with 1x2 hanging every 32 inches and lay the pex in it, is that acceptable or I would still need to put a cable clamp to hold it in place on each trough?
