Just bought a house and the building inspector did not check the perimeter drains. I should have checked myself.
It turns out they all they are all more or less plugged, with water only barely going down. I live in an area where LOTS of fir tree bits go down from the roof (needles, especially) and into the perimeter drains, and they have accumulated at the opening just under ground level. I had a company check it out, but there was no where they could get their scope/camera in to see the extent of pluggage.
Given other things, it appears the previous owner never tended to drains or the roof.
The company that did the scoping gave me an estimate of $40,000 for "complete Perimeter Drain replacement. Excavate around entire house, down to the footings. Clean and damp-proof foundation walls. Remove necessary concrete. Install a two pipe perimeter system. Backfill excavated area with clean gravel and native soil. Replace concrete, clean up and remove excess fill. Due to the complexity if this replacement, may employ the use of pipe-bursting or pipe-lining during the replacement where we deem it possible and within code guidelines."
Advice? Is there a way to pump out the crud that has accumulated, and then try to flush it out? Truth is, I can't afford the $40k.
Thanks for any help.
