p trap with Nibco 4895
elijawww
Dec 23, 2013
Hi, I am replacing my vanity, the sinks and top. The plumbing in this house is fairly new, 7 years old. It is 1 1/2" pvc, all glued. Since it is all glued I have to cut it off and start from the wall again.
I want to replace this P-trap with something that's easier to work with. I found Nibco 4895 is threaded, which means I can easily adjust, remove, clean it. Do i need to treat the treads with plumber's putty or teflon tape?
  • Like
Reactions: jdc
All my ptrap looked like the one you showed me, when I lived in NC. But in MA it may not be allowed. I found some poster has commented:
"in massachusetts, it is illegal to have a slip joint on the outlet side of the trap. however,if the p-trap is not the removable type, it must have a clean out plug in the bottom."
Come to think of it, I don't think I have seen jbend style ptraps in local Lowes. Explains why all the rest of the bathrooms and kitchen is all glued.
Does that mean I have to replicate what I have now, but substitute glued trap portion with threaded? I can't find any info on what goes inside that joint, some compression washer, Teflon, putty, or it's self seating.
IMO using glued-up piping for undersink drains is just plain wacky. Plumber's union in Mass. probably has some pull in the legislature, I guess. Personally, I would ignore it (unless I was a pro plumber, of course). If it's like the similar PVC/ABS items I've dealt with, the union-joint trap from Nibco you linked to seals plastic-to-plastic, i.e. no washer, no goop, no nothing. In my experience they are not very reliable.
Thank you for the reply, kreemoweet :) will take your advice into account.
