bathroom sink was severely clogged. No problem, took apart the pipes/p-trap under the sink and cleaned everything thoroughly (major yuck btw - clog was serious; i only have myself to blame for procrastinating and not nipping this in the bud earlier)
put everything back together and there’s no leak per se, but one of the p-trap’s slip nuts does feel very slightly damp if i press a piece of tissue paper against the threads. It’s super minor; i don’t even feel the moisture if i just run a finger around the nut, and it doesn’t result in any water droplet whatsoever, no matter how long i let the water flow.
p-trap/slip nut are stainless steel and tightened by hand.
is the minor dampness considered normal/acceptable, or should it be fixed anyway? (perhaps with plumber’s tape?) I tightened it real good despite doing so by hand; should i give it another quarter turn with a wrench? Was afraid of over tightening and damaging the threads.
thanks in advance
thanks in advance
