P-trap replacement
celife
Nov 19, 2013
55
I'm replacing a p trap and found that the pipe running from the sink is 1 1/4" and the pipe coming out of the wall is 1 1/2". The replacement p trap I bought is 1 1/4" which only works on the sink side. I could replace the pipe that comes out of the wall with the 1 1/4" pipe that came with my p trap, but am guessing it wouldn't fit on the far end. To make matters worse, the current pipe coming out of the wall no longer has a screw on nut or whatever it's called since it broke off. Not sure what my next move should be.
Yes, the threads on the wall pipe are still fine. The part that broke off was the nut. I don't think I can put a replacement nut on the wall pipe, but I could be wrong. One thing I'm curious about is: how is the other end of the wall pipe connected? Not sure what I'll be getting into when I remove the wall pipe to put in a replacement nut (or replacement wall pipe).
Since last posting I found a "reducing washer" from a prior p-trap problem with another sink. This allowed me to use the wall pipe that came with my replacement p-trap. My wall pipe was too long but I was able to use a hacksaw to get it to the right length. Everything fit great with no leaks! Victory pic attached.
Yup, that's where I was going with it.:)
