narwold
I have a situation where I'm building an addition onto my house for my parents to live with us. The addition is on one far end of the house, which makes hot water difficult. It'll be 70 feet or so just to get to the edge of the addition from the water heater, and another 30 feet from there to the farthest fixture.
Regrettably, the addition's structure is already built, and I didn't give myself enough space to add a water heater tank, because we're trying to be minimal with our requirements, and I assumed I would install a tankless heater.
As it turns out, however, tankless could be a challenge. In Ohio, the groundwater in online charts/maps that I've seen can be as low as 52°, and even the 36kw tankless units I've seen only give 4-5 (usually mid-4) gpm flow in the lower temperatures. If my parents happen to be taking a shower and running a load of laundry at the same time and someone goes to turn on the hot water at a sink, I would think it could overwhelm the system. First of all, does anyone not think that could be the case?
Next is the fact that tankless has additional complications/cost, such as upgrading my service.
I was trying to figure out if there were a way for them to share my hot water, but the distance seems to be a problem. Waiting for water presumably would be painful. I was trying to figure out if there might be a way to boost the heat at that distance without relying exclusively on heating water for the first time (stand-alone tankless).
One idea that I had was using a recirculating pump to keep warm/hot-ish water at the edge (the first 70 ft) and having a return pipe for that "trunk" portion. I was planning to run 3/4 pipe for that first 70ft and then branch off from there to my parents' fixtures. Does that seem like that could alleviate the problem sufficiently? What are people's thoughts on this?
Any other ideas?
Any other ideas?
