Nobili pl00118cr plus 118 bath faucet
Carl Campion
Jul 2, 2024
Hi All I was looking for some help on how to put a new Cartridge in Nobili pl00118cr plus 118 bath faucet Screenshot 2024-07-02 145027.jpgIMG_3062.JPEG
Only way to replace the cartridge is to it apart...go ahead buddy you got this 👍. If you don't have a spec sheet or something to guide you then I see your dilemma. We wouldn't know, or anyone really call the manufacturer and get the sheet.
Thanks for your reply I have picked up a new cartridge But can not find anything online to how it comes apart to install the new cartridge
Read this....
Thanks for all the help it went well The top ring just unscrewed and then the handle and then threaded ring holds the cartridge in place ( a tool for this ring came with the replacement cartage ) then just put it all back together carefully. Carl.
Hi All I was looking for some help on how to put a new Cartridge in Nobili pl00118cr plus 118 bath faucet View attachment 45866View attachment 45867
Hi Carl - I think I may be experiencing the same issue as you… I have that exact same tap and sink.
When I turn my tap on, the pressure is low and turns off if I turn the handle right to access hot water. The on and off lever also feels notchy and I only have access to cold water. Did you experience the same issue?
Also, was this the same replacement cartridge you ordered / used?
Thanks so much!
    589.6 KB
  • IMG_9647.mov
    47.8 MB
Hi Carl, I am having the same issue with my Nobili faucet. I ordered a replacement cartridge and can not figure out how to access the existing cartridge. Can you tell me how you did this? When you say the top ring just unscrewed do you mean the top ring in the photo you provided, the ring above the one that holds the handle? How were you able to remove this? Thanks so much for your help.
