OK friends, it's my turn to be the one in need. I just purchased a house that is going to need some work done. The first thing on my list is to eliminate the tankless water heater that the previous owners (complete idiots!) thought would look good by mounting next to the front door. The unit is mounted on wood, between studs. It has a 12" wood clearance perimeter warning, and no TPR installed on it.
I'm going to hire a plumber to either:
1) Reroute the copper lines to the back side of the garage, purchase a newer, safer tankless, and install it on stucco in the appropriate fashion.
2) Since I'm also ripping my A/C unit and installing a better, energy efficient unit, I will be removing the blower/heater unit from a closet and installing a horizontal position unit up in the attic. This will leave a big space to install a new tank water heater inside of this closet. I was told by a friend that the new code prohibits water heater installation in any inside portion of the house. I've seen hundreds of water heater closets, but mostly in condos and apartments.
Does anyone know if California plumbing codes prohibit water heaters to be installed inside of closets? And yes, if allowed, it will be vented properly.
Thanks!
Thanks!
