I recently installed a new Moen faucet in my bathroom. I used a standard 6" tailpiece extension to connect the Moen tailpiece to the P trap. The tailpiece and the tailpiece extension is plastic and the P trap is PVC. I used standard plumbcraft washers at both the top and bottom of the tailpiece extension. I did not use any tape or dope on any of the threads. After connecting everything and ensuring proper fit and tightness and careful not to overtighten or strip the threads, I ran the water multiple for extended periods of time to include filling the basin. I did this over a period of hours and there were no leaks or signs of water around any of the connections. In the morning, I checked the pipes and there was water leaking from the tailpipe extension washers...totally confused as to where the water is coming from since the sink has not been used since I tested it last night. Water does not seem to be leaking down from the top in the area of the flange and/or the pivot rod (they are dry) Any help is appreciated.
