Ewhitaker0020
Hey. I had a water meter set about 5 months ago and have never been ecstatic about the water pressure for my house. I should clarify that this is a brand new meter, supply line, everything is new. I checked the pressure once and I believe it was in the 20's. I live about 350' away from the meter and about 20' above it. A guy I worked with that lives in the same county had the water department come out and adjust his pressure up at the meter via some sort of locking adjustment screw. The water department is supposed to come out here Friday and check if my meter can be adjusted as well. I took a bunch of pictures of it for you all to look at. Can you tell me what you see? Is there any way to turn up my water pressure?
https://imgur.com/a/0o0cl
