The two drains on either side are for the sink drain and disposal, the one at the top is a clean out. Strange configuration but that's the only explanation I can think of. I'm not 100% sure but I believe that is a cross between the two stub outs in the picture and is supposed to be a double fixture fitting. Maybe someone else can confirm?
What you missed is above the waste line on the left side is a outside faucet than needs to be connected to the cold water line after the sink cabinet is installed.
John, you are a pure genius. How the hell did you figure this out?
You are correct in your explanation. The advantage of that setup is if the disposal should become clogged you will still have the use of the other compartment in the sink. What you missed is above the waste line on the left side is a outside faucet than needs to be connected to the cold water line after the sink cabinet is inatalled.
