our old hot water heater, a 50 gallon unit installed in 2000, died recently, as it split its side seam from excessive internal rust & corrosion (luckily, it only seeped water into pan when I found the problem, it did not split open and dump entire contents onto our first floor) ....I replaced (myself) the old unit with a brand new Rheem 50 gallon unit, but we now have a major problem: the hot water runs out very fast ...?? all our water for entire house will be gone after 1 regular length shower ....?? ....and with our old unit, we could not only take a shower, a long one, and do dishes or wash clothes on hot, but we could take 2 showers and the hot water would not run out .....??? .....again: they are both 50 gallon units ....can someone please tell me what is going on ?? ..I have experimented with various degree settings on the upper & lower thermostats on the new unit, from factory setting of 125 to 135 to 145 to 155 (max) and although the delivery of hot water is fast & constant, it runs out fully unbelievably fast ....?? ....here are photos of both the new unit the the one I removed ...THANK YOU for the assist
https://flic.kr/s/aHskqNHSK2
