Hello,
Thank you for taking time to read my post.
Background information:
House was Built in 1995
The other day, I came home from work to find a lot of water on my kitchen floor. After troubleshooting for a bit, I found the source was actually coming from my outdoor faucet. I tore all of the wet dry wall and insulation away and found that I had a huge crack on the pex pipe that was going to the outdoor faucet (I have pictures attached).
I think I can manage replacing the pex pipe, it doesn't seem too hard to do that (however, if you have any recommendations or new plumbing pipes/connections that you want to recommend I am all ears). However, I am a little bit concerned with the general design of my system. I don't think, with the current system, that there is any realistic way to get all of the extra water out of the pipes for winterizing the outdoor faucets.
In the attached images, I have a pictures of the shut off valves (the red shut off valves). There is one shut off valve for each outdoor faucet. The pipes go straight into the foundation and under the foundation (the house is on a slab with no underground access). The pipe then come up out of the foundation and connects to the outdoor faucet. This kind of makes a giant "U" shape. The problem is that the shutoff and the outdoor faucet are about at the same height, so I think that extra water is laying in the pipe, even if I kill the supply.
First question: Do you know how I would be able to winterize the outdoor faucets with this current setup? I very well could be missing something.
Second question:If I replace the shut off valves with (excuse my lack of technical terms) the shut off valves that have those little nuts that you can unscrew to let air into the side of the pipe that you are trying to drain, then could I hook an air compressor and gently blow the extra water out of the pipes?
Would this likely break my pipes over time?
Does this sound like a good approach, or is their an industry standard way to do this?
All advice is welcomed.
Thank you for taking time to read this post.
Respectfully,
James
Respectfully,
James
