Plumber came and added a Recirc Pump to my setup but he did it this way. Image attached.
I installed the comfort valve on the further most faucet. But when i put the Grundfos recirc pump on the Hot Water Heater does not come on and i still don't get water quickly, takes up-to 6-7 minutes? I also see no check-valves in the plumbing install. I see a Ball Valve (which i believe is a shutoff valve) but no check values.
I've marked the Return Line with Red (B) and the Cold Line (A) with Blue
I think this is a wrong setup. Any suggestions please ?
