Greetings! Do you have an experience and can you recommend a solid, reliable, off-the-shelf booster pump for bringing home pressure up to 60-75PSI, rated flow 15-20 GPM?
I've read so many bad reviews with various Home Depot brands, mainly leaks and deterioration in a short time. Leak issues are reported even with Grundfos SCALA2 (the reason I find SCALA versatile is because it's self-priming, it has a built-in speed control, non-return valve, uses standard outlet plug etc.
However, if it's coming with issues, it's worthless. Is there something more robust but residential (or even light commercial)? Thanks for the advice and recommendations!
