Ray
I'm trying to hook up my pump to the river in order to water the lawns and flower beds. My pump is old, but works fine. However, I can't get it hooked up, because the threads in the holes where the drain plugs go are so rusted that the drain plugs won't thread in anymore. There are two of them. I went to the hardware store, got a 1/4" tap/reamer and reamed out one of the holes. The tap worked fine and reamed out the hole, but when I tried screwing in the new plug (the old plug was pretty rusty and the threads were worn down), the plug wouldn't tighten; instead, it just kept on moving into the newly-reamed hole. It would just keep on moving into the hole and would continue to do so until it simply fell into the inside of the pump, if I were to keep trying to tighten it.
What did I do wrong? Did I go too far with the tap/reamer tool?
How can I just plug those holes? I don't care about the pump freezing & cracking, because I always bring the pump inside during the winter anyway, so I don't really those holes and plugs, anyway. I still have a third hole & plug through which I can prime the pump, so that's not a problem. Is there are way that I can just plug those two other rusted holes? The water pressure gets up to about 60 p.s.i. before it switches off, so I need to be able to put some kind of a plug that will not leak and will withstand that much pressure.
Any help would be greatly appreciated.
