I have a house that was built in 1986 with copper plumbing. I have 3 water spickets on the outside of the house that need to be replaced / repaired. They are soldered directly onto the copper plumbing behind the wall. I don't want to tear down the siding on the outside of the house or the drywall inside the house to remove and solder on new spicket valves.
I couldn't find new valve stems or proper replacement washers for these exact spickets anywhere. The cap on top of the spicket, where the valve stem comes out is 3/4" with a compression fitting thread pattern, not standard pipe threads.
My idea was to remove the valve stem, cap off the top of the valve where the stem used to come through, and then screw a new ball valve spicket on the old spicket end which would give me a new good valve and eliminate having to tear down siding or drywall all around the house.
My problem is capping off the top of the old spicket where the valve stem used to come though. The fact that the top where the cap screws on is 3/4" COMPRESSION threads and not standard pipe thread really is a pain. At ACE, they have 1/2" and 3/8" compression threaded caps, but not 3/4" and I can't seem to find 3/4" anywhere online either. Any ideas how I can cap off the top of this stupid old valve?? Can someone fine me a place to order a 3/4" compression threaded cap?? Right now, I jammed a rubber stopper in there and screwed the old cap back on and it seems to be fine, but I don't see that as a reliable long term solution. Please help!!
