Dear All,
I have just bought a domestic water tank and need some advice. I would like to set it up on the roof of 2 storey building as in my region water supply stops regularly.
I want to use gravity for the distribution and won't use pump. My main water supply should go directly into the tank and to other outlets such as shower, toilet, kitchen....etc.
I only need water stored in the tank during water supply cut. Does any one has a better way of doing the installation?
Please find below a schematic I was planning to proceed with:
Is there a way that water in the tanks flows out automatically when the main water supply is cut? Else each time the main water supply is cut I have to get on the roof to open the 'stopper' or close it.
Thank you.
Best regards,
Yannick
Thank you.
Best regards,
Yannick
