wangy26
Our house was originally built in 1993 and had polybutylene water piping. We purchase the house in 2005 and did not realize the potential leaking problem associated with the poly piping and didn't know the lawsuit and settlement for the poly piping. Today we found the water leak from the kitchen ceiling (1st floor). It was probably from the water pipe leak.
I did some web search and found out that the poly pipe is susceptible to leak sooner or later and should be all replaced at once. So here are my questions:
1. Should I just repair the leak for now (it will involve cutting into the ceiling dry wall to repair the pipe leak) and wait to see if there is more leak later? We did not have water leak for the last 6 years we lived in the house.
2. Should I just replace the whole piping system once for all?
3. If I replace the whole piping system should I go with copper or CPVC (or some other plastic system)? What is the pro or con with these different systems?
Your help would be greatly appreciated! We need to make decision soon.
Thanks!
Thanks!
