DIYhomegymheater2019
I am replacing a old natural gas that I never used before, the line in the house is 1/2" I had two quotes from two different gas companies that have permits wanting to run 1/2" copper which is another reason I decided to replace the old 3/8" line with 1/2" poly with black pipe line. Also went with 1/2 because of using a chart like this
http://snowcrest.net/thriftysupply/pdf/NAT-LP-PIPE-SIZE.pdf
Due to a poor description and title from home depot and not seeing the tiny fine print at the bottom I purchased this without realizing the risers are 3/4" the 100 feet poly line is 1/2 but they turn into risers that are 3/4 ( I have 3/4 to 1/2 elbows to fix this issue )
https://www.homedepot.com/p/HOME-FL...2-1-2-in-Meter-Risers-18-429440-005/311074240
I confirmed that there are not risers like this that go from 1/2 to 1/2 at home depot or elsewhere however they do have another kit that has small flat 1/2 pipes that are 5.5" not safe enough to use as a riser imo. If I really need to I could create my own risers with a elbow and 10 - 20" pipe and use the kit below if using a 3/4 will cause a flow or pressure issue.
https://www.homedepot.com/p/HOME-FL...n-Transition-Fittings-18-429445-005/309020455
This is a time sensitive project I would prefer to use to just use what I have now but not sure if it will end up into safety issues or pressure drops etc or what ever could go wrong.
I get that your gas pipe is rated only for what your smallest size pipe is and also the length of your gas system. I just can't find any info about going from a smaller size to a larger size back to a smaller size pipe 1/2" ( house ) to 3/4" ( top of riser ) to 1/2" (bottom of riser ) to "to 1/2" ( bottom of riser ) to 3/4" ( top of riser ) to 1/2" ( garage pipe ) to a 3/8" ( appliance ) which is a mr heater 30k btu heater.
My question is will having a line that is all 1/2 but having the risers that go from 1/2 - 3/4 with 3/4 to 1/2 elbows cause issues in pressure. I am running a line that is 33" feet outside about so let's say 55" to count the house inside and the garage piping for the sake of safety and margin of error.
