Idk what's wrong with it, bc if I poke it with a broom it starts back up? Anyone have suggestions before I spend a grand on a plumber? (The pump is only a year old and was self installed by a personal handyman)
Is the float getting stuck on something?
Ok when it's done pumping all the water out, I'll take a look at it and see if I can do that. Thanks!I'd bet the floats getting stuck, should be ziptied to the pipe in a way that it raises a bit to pump and so it won't get stuck.
I don't understand your comment. The controller is $75.For $350 I would rather the float switch.
That's interesting. I am in MD and when I click it it shows $75. The link must change to your location.The one in the link you provided says $356cdn
