This house recently had a bad sewage backup in the basement sump well.
According to the plumber, the backup was caused by a rootball about 25 feet away from the front of the house. The plumber snaked and cut the rootball so now everything seems to be draining properly. (Water or solid waste has not returned to the sump sense the pipe was snaked.)
We initially noticed the problem when we smelled a strong sewer gas odor coming from the basement. The problem seemingly happened overnight and resulted in about 3-4 inches of solid waste backing up into the sump well. I cleaned the solid waste out and used many, many gallons of water from a garden hose I dropped into the basement. The plumber (and a cursory search of the internet) led me to use bleach with the water. The cleanup was successful in removing the solid waste, but the smell is now very musty with a slight, sewer smell.
Other details...
There is another drain near the sump well, but I've smelled both the drain and the sump well, and the smell is definitely coming from the sump. I'm at a loss as to what to do next. I just need to remove the smell for good. Here are some pics that may help. The sump has two large pipes that are on either side of the well and I tried to show that in the pictures. I'd appreciate any feedback.
Thanks.
Other details...
Thanks.
