LeftyLoosey
Last week I posted about getting a new sump pump and battery backup installed in my basement. Initially when the installer put in the new submersible pump he put a check valve in about halfway up the discharge pipe - approx 3' up from the pump. The pipe then continues for another 3' or so before turning and exiting the basement. I had a different company install the backup pump and they took this check valve out and put in a check valve at the base of each pump. The system seems to be working fine but when the sump pump finishes running all the water in the approximate 6' of discharge line runs back down as the original check valve is no longer there.
I've read one of the reasons for the check valve is to prevent the pump from re-pumping the same water and to relieve some of the strain on the pump over time. It's also fairly loud when the water is running back down the pipe.
I have the original check valve and it would be a very simple matter to reinstall it in the vertical discharge line a couple feet above the 2 pumps. Is this a good idea to do? Is there any reason NOT to do this?
Thanks.
Thanks.
