toddj
Hola.
So I was digging the hole to put in an egress window to my basement and came across my water supply, which is butted right up against the outside of the house.
Can I shut off the supply at the street cut the pipe and put a 90 straight down, then across the bottom of the my window well and then straight back up the other side?
If so, this pipe appears to be cast iron, what is the best options for makeing a LONG lasting connection that will be under the ground. I know PVC is good options but is using those rubber boot connectors from the CI to the PVC a lasting solution?
