I'm in the process of replacing a plaster ceiling in the finished half of my basement, and I figured since I have full access to everything now would be the time if I were to make any changes to the radiator piping in this area.
As it was before ripping out the ceiling, the pipes just ran exposed along the ceiling, but this obviously doesn't create a very finished look. I've attached a diagram that shows roughly where the pipes need to be going - it looks like currently there is a combination of 1.5" and 3" cast iron piping, and a good portion of the run is perpendicular to the joists. The room is about 24' wide at the widest area.
The height of the pipes pretty much rules out dropping the ceiling or boxing them in - the resulting ceiling would be too low. Is there any hope of changing things around so that they could run in / through the joists? I'm not planning on doing this myself, but would like to know if it's possible before I spend time looking for a plumber, getting quotes, etc. Also if it is possible, it'd be good to know if it's so involved a job that the price wouldn't be worth the outcome.
Thanks!
EDIT: Update drawing to include the both in/out connections for the main floor radiators.
Thanks!
