Moving kitchen Drain
branimal
Feb 27, 2017
210
12
NYC
I am renovating my kitchen which involves moving my kitchen sink. My condo board wants to know how I will be accessing the drain in the new location.
Below is my current setup and my new setup. Without opening the walls I can only guess how the drains and vents are setup.
Assuming there’s sanitary tee at the existing kitchen sink location, can a 2” drain be wrapped around the wall as shown in the new layout picture? The drain will slope 1/2” per foot and be within 8’ of the vent.
It is also possible that the vent stack wraps around the wall in the same direction as the new proposed drainpipe. That would make the job a lot easier.
Thanks
1/2" slope only allows you 4" to your vent. 1/4" will get you 8" but code only allows 135 degrees of change in direction, you have 180. Instead of using a 90 degree elbow under your cabinet, use a 45 degree elbow and shoot your trap directly into that
Good call on the limit in direction change. Yup I meant to write 1/4” slope per foot. Thanks!
