Higgy
Hi ..New to the forum so thanks in advance for making it available!
I am going to install a bath tub/shower combo where there was just a shower. See pics.
Shower had center drain in concrete slab: house built in 80's I believe So. Cal
* when facing tub...
The tub would be a left hand drain as the copper pipes from existing shower are on the left (an exterior) wall side..
Toilet and vanity are on the right wall.
I opened up the floor, dug out around the drain & ptrap and found the 3 copper lines going across...up thru the base plate of the wall to the shower valve.
They seem to be in the way of moving the drain for the tub.
And, I need to know what you recommend to get it right.
The OTHER SIDE of the opposite wall is another bathroom with a shower tub combo (toilet & vanity side) and has copper for the sink in the pic...
* is the black pipe the vent portion?
* can or should I cut the copper in the ground & re-route?
* how to vent properly if necessary on left?
