kitchenredo
I am planning to move the kitchen sink to an adjacent wall. My question is about routing the drain. To tie in to the existing drain connection in the wall, I will have to run the plumbing after the trap 90 degrees, about 3 feet behind a cabinet, another 90 degrees, then about 12 inches to finally meet the drain at another 90 degree connection. I have enough vertical drop for good drainage, but I'm worried that the distance and multiple turns might be a problem or against code in NJ. Do you think this will work, or can you suggest other options?
